B18B1 swap questions.
Hi, I'm currently in the middle of gathering parts for a B18B1 swap into a 98 Ek hatch. I have a few questions they might sound stupid but its my first swap so give me a break.
I took the B18B1 out of a OBD1 1994 Acura Integra LS and I am putting it in a 98 ek hatch which is OBD2A. I was told i can use my stock engine harness from the D16 and also use my distributor off my D16 for the B18 and then for the ecu I was told to get a OBD2A to OBD1 jumper harness and then plug the ecu in and it should work fine is this true?
Thanks.
Thanks.
Technical Hero
Re: B18B1 swap questions.
The D16 distributor will bolt up to maybe one bolt and you're timing won't be right. Check here for the all the wiring you'll have to do:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
impactblue2ner
05-27-2004 08:43 AM
