OBD1 LS INTO OBD2 INTEGRA
I read this FAQ and I'm a bit confused... https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/ It mentions "You can actually use a US OBD1 engine wire harness in a 96-01 integra. You heard me right. 96-01 Integra's all retain a 2-piece wire harness design. Honda thankfully made the break off plugs backwards compatible with OBD1 EWH's."
I have an obd1 LS motor that I am putting into an obd2 96 Integra chassis. From what I understand the obd1 LS engine harness I have will work with the obd2 chassis/body harness. I then plan on using a jumper harness to run an obd1 p75 ecu.
Can anyone tell me what problems I'll encounter?
Nisif
10-20-2012 06:11 PM
