89 ef sedan 4wd b series turbo build
This is the start of my crv awd b series swap into my 89 ef sedan
i will be posting every day to here .or as i build the car
Re: 89 ef sedan 4wd b series turbo build
i worked on removing the factory passenger side mount off the car i drilled out the spot welds
then i pulled the mount off with a little work
https://honda-tech.com/attachment.ph...1&d=1390976537
here is the frame rail cleaned up
here are the mods to the t bracket to make shift cables fit
https://honda-tech.com/attachment.ph...1&d=1390977395
https://honda-tech.com/attachment.ph...1&d=1390977452
https://honda-tech.com/attachment.ph...1&d=1390977524
https://honda-tech.com/attachment.ph...1&d=1390977620
now time to reinstall the t braket and the transmission in the car and start to build a passenger side mount braket like the original one will have pics tommarrow with that
here is the mount i will be modifing from my innovative kit i had on the car before
https://honda-tech.com/attachment.ph...1&d=1390977945
i ordered a 3/4 inch this 5 inch by 7 inch piece of 6061 billet sheet to make the base for the transmission lower part of the mount
the plate came in today to make the custom transmission mount
its a 5 inch by 7 inch 3/4 inch 6061
https://honda-tech.com/attachment.ph...1&d=1391024171
this is how it will look when all done
here is the template i made and the transfer to the aluminum plate and drilled the holes
https://honda-tech.com/attachment.ph...1&d=1391033383
https://honda-tech.com/attachment.ph...1&d=1391033518
here is how the mount will mount to it
https://honda-tech.com/attachment.ph...&d=1391033680\
https://honda-tech.com/attachment.ph...1&d=1391033680
here is a update for everyone watching
i have been working on the rear trailing arms this weekend and its really tedious work
enjoy the pics
here is the crv control arm cuting out the center
https://honda-tech.com/attachment.ph...1&d=1391394297
https://honda-tech.com/attachment.ph...1&d=1391394424
https://honda-tech.com/attachment.ph...1&d=1391394514
enjoy the pics
motor mount fab for transmision
https://honda-tech.com/attachment.ph...1&d=1391733497
https://honda-tech.com/attachment.ph...1&d=1391733879
https://honda-tech.com/attachment.ph...1&d=1391734030
i have a new update making the shock brackets to off set the shocks
i still need to grind it down and clean the welds and on the top pf the shocks i have to make a space to make the shock sit angled
here are the pics
https://honda-tech.com/attachment.ph...1&d=1391992209
https://honda-tech.com/attachment.ph...1&d=1391992334
here are the pics
xkagax
07-14-2008 07:07 AM
