y8/y7 mini me with stock p2p ecu
im concerned about the stock p2p ecu being able to run this motor properly.
has anyone hooked up a wideband to it after doing a mini me?
i was planning to bump up the compression since im doing it
2 layer headgasket and milled head to get around 10.2-10.3 cr
stock exhaust cat and short ram intake
Re: y8/y7 mini me with stock p2p ecu
Wideband gauge to see if it actually runs with proper afr. Could use vtec controller or something if i find a good deal. I mean i have everything to tune obd1 i could just get a jumper harnesd but then i will have to do tailpipe test instead of plugin.
mengy007
01-12-2007 11:50 AM
feriob12
11-22-2003 10:20 PM
