del sol swapping in a b18b1...some questions
This is the first motor swap I have ever done (not that I am doing the swap but I've never had anything like this done to a car before). I bought a motor from a friend (I got the see the motor running and drove the car before he had it pulled)...
the motor is going in my 93 del sol...the motor is obd2 so I already picked up a obd1 ecu and distributor (distributor isn't pictured on the motor yet)
but he kept the clutch and fly wheel(stage 4 clutch which I didn't want and light weight flywheel)
so the transmission is missing things it looks including the bolts to mount the trans to the motor...but basically anywhere there is a screw hole can someone please tell me what belongs there... I want to gather up everything I need because I am going to take my car to someone to have the motor put in and want to make sure I have all the needed parts. also my car currently has a d15 in it...can any of the bolts off that work for this
trans
intake manifold...two screw holes next to the hoses...also missing a nut to hold the fuel rail on right?
above the header two screw holes
driver side motor mount.. I'm missing one of the 3 bolts to hold that mount...
behind engine...I take it this is another mount as well?
passenger side
As far as I know here are the parts not pictured I have
-obd1 distributor
-obd1 ecu
-vtec del sol shift linkage
-oem flywheel
-competition stage 1.5 clutch
-b18b1 wire harness
on my list of things to get still
-axles
-half shafts
-mounts
let me know if there is anything else I am missing that you can think of and if there is anything off the stock motor I can use as far as bolts. Thanks
[hr]
also if anyone can point me to places I can buy any misc stuff online new I would appreciate it. I know I can go to local junk yard but here in MD its been like high of 18 degrees...so a little to cold for me to go to a junk yard for parts.
trans
passenger side
-obd1 distributor
-obd1 ecu
-oem flywheel
-b18b1 wire harness
-axles
-half shafts
-mounts
[hr]
Re: del sol swapping in a b18b1...some questions
That's alot of pics so it'll take me some time to digest --
In the mean time, the best way to sort out the missing odds-and-ends is to go to the website for a dealership that has an online parts catalog (hondaautomotiveparts.com, etc.), and compare what you have on-hand to the model car that had this particular configuration.
(Looking at your pics...)
currently in the car is a d15b with stock harness stock ecu for 93 del sol s model
for the swap I have b18b1...obd2 motor and harness but I have a obd1 ls distributor and a obd1 p75 ecu which is what I was told I needed in order to convert to obd1.
pontiacman63383
01-21-2019 04:42 AM
