obd1 injector clips to obd2 injectors
just recently found a set of obd2 injectors and need them to fit obd1 clips.. preferably without hacking the harness or spending $60 on adaptors from rywire.
I have heard that you can cut the off center tab on the injector to make it fit.. just wondering if there is any truth to this.
Re: obd1 injector clips to obd2 injectors
You can take out the blue "plug" and they will will pop right in , you will have to zip tie them so the clip doesn't slip off. Here is a description http://www.ff-squad.com/tech/wiring/obd2-1injclip.jpg. You can also cut and splice them on to your obd1 harness, which imo is better if you can solder/heat shrink or do a decent crimp job
Yea I know.. I just don't like to cut into the harness if I don't have too but I'm almost positive you can snip the tabs.. I guess I'll find out when I get them haha
RBNightMare
02-13-2007 11:50 AM
