H2B What slicks, what psi to run at track? HELP!!!
i drive the car currently on Mickey thompson ET 2 ST Radial 215/60/14s.
Car seems to dead hook on the street no lift shifting to second gear.. first gear from a dig not so much but i havent heated them up or anything.
im just wondering if i will have more traction issues at the track vs the street
on street launching at 3500rpm theres minimal spin but when i bring it up to 5k and launch its alot of spin.
i dont think i will be launching at no 3500rpm at the track in fact i was guessing it will be way higher after watching film people are fearly close to redline.
im runing Neptune RTP so im not manually launching just curious if i should just play with it when i get to the track.
also what psi are people running on these ET 2 STREET RADIALS? IM RUNING THEM AT 20PSI COLD ON THE STREET....
Car is making mid 220whp and 160wtq on a mustang dyno with some more tuning coming i expect to see mid 230s/170s by race day
Thanks in advance!
Thanks in advance!
Re: H2B What slicks, what psi to run at track? HELP!!!
thanks for reply!
i had 24s slicks@ 8.5 psi on my h2b"f20b" with 218ish whp my car bogged no 2 step taking off at 8k I was bbying it a little to save the axles I say 23s are perfect
your car must be on e85 or built head for those number
1 Post
with your setup i would try 8-12 psi and im guessing your rpm launch would be 3-5k with these tires at the suggested psi. with my b20vtec making power in the high 180 to low 190 hp range i used hoosier r6 185/60/13 radials on vx wheels 12psi launching at 3k with no 2step set and i was getting 2.0 60fts.
Nextelbuddy
23
10-04-2003 02:46 PM
