H22 swaped eg. Wont get spark need HELP!!!!!! PLEASE!!!
Hi i have a 95 civic hatch with a h22 swap. One day i was driving and the car kinda just shut off. It didn't exactly just shut off tho it felt as if the the gas pedal just didn't do anything anymore. then i just coasted to a stop and it shut off then wouldn't start up at all. I checked for spark and i have none. I have fuel and compression and timing belt didn't snap or skip.
Ive tried a new coil a new rotor and cap and a new icm. I Checked the ignition fuse and ecu fuse and all others, there all good. The main relay clicks if that matters. ummm iv also checked for power to the coil, that's good.
The one day i went out to my car with another coil (like the 3rd good one i tried) and it started up. I drove it like 10 miles to my buddys house and it seemed good. Then i started it up to drive into the garage and it did the same thing and hasn't started since.
Thanks in advance for all your help. I REALLY NEED TO GET THIS THING UP AND RUNNING AGAIN THANKS.
Re: H22 swaped eg. Wont get spark need HELP!!!!!! PLEASE!!!
do you have a CAI i have one and took on water and my engine does the same as what you are describing now and in my case the problem is most likely my injectors.
