99 civic hatch h22a swap limp mode help!!
Hi I have a 1999 honda civic hatch that has a h22a1 swapped from a 92 prelude. It runs and drives very good. The one problem I have with it is the wiring harness to the ecu. Whoever did the swap did something weird with the harness and if someone in the passenger seat kicks the harness on accodent it throws my car into limp mode only having the rpms at like 200 on warm idle. After messing with the harness for a while I got it back to 900rpms at warm idle. The problem is that my cel won't go away even after restarting the ecu and I don't seem to be getting as much power as i should especially when I am in v-tech. I have also noticed that if I am driving down the highway in 5th every once in a while my cel will go off my car will shudder a little then the cel goes back on. It is confusing me so if anyone has and advice/info for me it would be greatly appreciated. Thanks.
If you loved me, you'd all sell me your magic cards to me today
Re: 99 civic hatch h22a swap limp mode help!!
Use the link in the FAQs to jump the service connector to get the code.
Okay sorry it took so long for me to reply again. It threw a code 10 and a 21 which are the intake air temp sensor and the v-tech air solenoid valve. Any ideas on how to fix those?
efsedan
06-26-2007 05:56 PM
Nate047
02-20-2007 11:36 AM
