h22 vacuum/wiring harness problem. (yes, a big problem)
Hey guys, its me again.
yesterday, i looked at the engine bay and the wiring harness. iam getting grazy with that harness from uk. There are so many plugs and vacuum hoses left >.<
i searched yesterday and today after vacuum diagramms and wiring harness diagramms, but it wont work. i don't get it ... >.>
it would be very cool, if someone can help me with that.
every plug/ hose have a number .. i hope, we can figure out, what plug comes together with someone other.
correct me, if iam wrong
3 = active filter?
7 = egr plug
11 = anything with the tacho, i think..?
12
13
15
Thanks for help, guys!
3 = active filter?
7 = egr plug
12
13
15
3 is cruise control. Block that off. 4 is for the air boost valve. Block that off if not using it. 5 is for the iab you can plug it into the intake manifold and use it off of a little vacuum but unless your using a p14 ecu it's worthless
9 and 10 are for the charcoal canister. If you have one plug those in. If not then plug em. 12 is a trans breather. During be swap you won't use some plugs so don't be worried if everything isn't plugged in.
Re: h22 vacuum/wiring harness problem. (yes, a big problem)
Ok, thanks
ist that tut a h22 tut or a basic engine tut about vacuum /wiring harness?
a friend said, number 14 is for the transmission, the speed sensor. do you think, this is possible?
Really? i read something about other wiring at the transmission.
dont know. Do you have any informations for me, what ecu i need ... a link to a tutorial would be very cool, too. (if there is someone)
My problem is, my english isn't really improved for searching hours about millions of english threads. sorry for that.
iam trying to help men but you got to be more specific....
#1 what harness are you using??? or what car is it going in???
#2 what have you plugged in already? and where (dont post all picture at once lets go slow)
# 1 its the ek3 harness, i think. The pre owner had no infos about the car.
# 2 nothing. Today, iam going to my garage And look .. i get alot infos from german forums.
I will post my new photos And infos here.
