h22 civic, which throttle cable
So I had to change my throttle cable when I did my b16 swap, I think I used a Da throttle cable.
The cable is way too long for the h22. What throttle cable can I use? H22 prelude? Does it fit the gas pedal?
Re: h22 civic, which throttle cable
Throttle cables for LS/B16 mount too far away from the TB to use, most D16 EG/EK and H22 Prelude cables are short enough. The D16 cable will require the bracket on the plenum to be moved one hole over to the driver's side, using only one hole.
If you have a "long" cable, just get the 97-01 Prelude cable. It's $25 shipped from most online dealerships, half that from a junkyard.
Keeper1343
08-28-2007 12:23 PM
EGhatch22
06-20-2007 12:43 PM
StickyDilJoe
04-13-2003 12:55 AM
