Latvian Civic EG AWD Vtec
litlle bit about civic
1992 year, d15b2, but swapped in d16z6
I will report ,here, review of my awd build .I get the rtsi chassis parts except rear suframe and fue tank, and shifterlever
so i started with rear trailing arms, rtsi trail. arms is longer than hatc arms, so i shortened them and welded from two pieces into one
new on vs old orginal
next one is tranny S22, to get and bolt it , i was move tranny mount about 3 cm to front. I know there is a lot of mud :D
drilled in factory weld points
and now welded in
next was shifter lever, i bought from 4th prelude, but prelude mechanism is different,all transfer switches contrary. i built new used preludes mechanism
drilled hole for shifter lever cable
to get tranny together with engine , there was problem with oil pan
i cut corner out
exaust
engine together
Rear of car
differntial mounts upper
and rear mount
main shaft was shortened
rear together
rear right axle was extended
exaust
ther is more pictures i will post them later
ther is some videos
(crashed little bit iin end of video)
and now welded in
i cut corner out
exaust
engine together
Rear of car
and rear mount
rear together
exaust
ther is some videos
civicmatt
44
06-16-2003 07:22 AM
