b18b1 swapped into 2000 ek civic - Ecu Problems
Have swapped a b18b1 ls trany into an ek. Running a P75 ecu with all the wiring mods performed. Car starts, idles and drives, but the issue is that the ecu is not firing the #1 injector. Have checked my wiring and performed a noide light test right at the ecu pin for #1. Tried running a chipped P91 and it has the same issue only with injector #2.
Has any one had a similar problem. Have read through countless forums but none which deal with this problem.
brasiliangee90
07-11-2009 10:07 AM
