J series swap
J series swap
Would a J series swap be worth the swap, I know they put up big numbers but will the weight cause bad traction along with unbalanced chassis issues?
Re: J series swap
What chassis are we talking here and what is your planned use for the chassis? Do you have a realistic budget? Who is going to be doing the swap, fabrication and welding?
please give us more to go on..............
Re: J series swap
chassis can be balanced after the swap to suit the application and setup, that is if you want to get that serious about chassis set up.
Re: J series swap
Chassis= Ek
Motor= J32 or J30
I was just stating what I read about the traction, but I have around 5k I would love to do a K24, but their still pretty expensive.
I know the j series motor is a pretty well engineered motor I just want to know if there will be problems with swap It'll be a weekend warrior/DD car as well
Motor= J32 or J30
Re: J series swap
Chassis= Ek
Motor= J32 or J30
Motor= J32 or J30
-Eric
Re: J series swap
Yea Im not slammed and dont look foward to it , but I was worried about the oil pan clearance and from reading it would be like 4 inches
Look up adjustable j series mounts and hondatuning. Should lead you toward the article they had about the two setups. Yes ground clearance is a little more than normal but how bad *** would it be because no one would expect a lifted civic to haul *** with 6cyl
-Eric
-Eric
Personally have been wanting to do it for about a year now but a lot of things have gotten in the way.
If you got the drive for it then anything is really worth it. All personal preference when it comes down to it
-Eric
-Eric
Re: J series swap
however, if my power goals were anything near that of a typical J-series I would much rather do an H/F-series with a turbo. Just for the sake of packaging and hood clearance. Sure, the J-swap gets loads of cool points and it's getting easier to do with mounting and wiring solutions but there are too many other compromises (for my tastes) just to get it in the bay.
Re: J series swap
they are really sweet engines. smooth and torquey without being whezy up high.
And I thought about boosting my b series, but the more you build the less reliable your motor can be and the longevity is taken away.
Re: J series swap
sure, to a degree. however with good quality parts, good build practices and attention to detail you can have great reliability and durability. the H/F-series has even more margin than a B-series because of the larger capacity and overall size.
Re: J series swap
The torque alone that the J motors put out with being bone stock makes it worth it. It would be ultimately more reliable than swapping a b,k,or h and boosting it to even get it close to the hp and torque values that the stock J's put out. Heck with swapping heads you can reach up to 300hp and comparable ft/lbs of torque. Like hondamark35 said you can simply run higher spring rates to fix the issue of the extra weight. Also there is only around 100lbs difference between a k24 and a J-series depending on 30-32-35-or 37 but keep in mind how much weight do you think that whole turbo system weighs bolted up to the k24 and people have no issues there.
Re: J series swap
Re: J series swap
search for project no name (eg sedan) by pink batman. I found this build very informative for how much work it takes to j-swap a honda. good luck, it looks like a blast to drive.
Regards
Dave
Regards
Dave
Re: J series swap
That makes complete sense, but why are people complaining about the weight distribution and other problems such as under-steer (autox racing) if they k24 and J32a2 are similar in weight? Sorry for all the questions haha All the research I do on J swaps takes me back to 2009-2011 and alot of K people talk the J down.
My build im doing on my 91 hatch is going to have the 03TLTypeS j32a2 04 TL 6Speed LSD factory equipped. Cable to hydro converstion. DA spindles to allow use of the bigger brakes on the integra. Complete poly bushing kit Sperical trailing arm bushings, rear subframe brace with a minimum of a 21mm sway bar. but the big thing to help change from under steer to over steer is by going with a 15x10 rim with 275/35/15 in the front with 15x10 rim in the rear with a 245/40/15. and testing with different spring rates.
Re: J series swap
just a thought, too new to Hondas, but reading on either having engine through hood, or oil pan hitting because of clearance issues, can it be dry sumped, with remote oil tank?
I dont know particulars of the engine, but first thing that popped in my mind.
Re: J series swap
I think that's why 10 minutes with a sawzall is the go-to solution.
