h22a1 civic start up problems please help!
Okay so I have a 1999 civic dx with a h22a1 swap. For about the last week I've been having trouble with the ecu wiring harness. If it gets kicked it throws my car into limp mode.well it got kicked and after messing with the harness I got it to run normal again but the cel turned on. The code was a 21 for v-tec spool solenoid valve. Thinking that it was just something with the harness I messed with it and was able to get the cel to go away and had it driving 100% normal again. I drove around for a min and going home I turned it off. Like literally 5-10 min later i went to start it and now it won't start. Its so weird because just before it was running great. The motor will start to crank but won't turn over. I have checked the battery and it is fine so idk what it is. If anyone has any advice that would be great because I am stumped. Could it still be the wiring harness? Thanks
Re: h22a1 civic start up problems please help!
youre the only one that can check your wiring....theres no way that we can answer that for you.
other then that check for fuel and spark..or look at one of the thousands of no start threads.
Well yeah I know, I'm gonna check for fuel and spark a little bit later but is there anything specific I should look on the harness? It looks okay to me nothing seems cut or unplugged
MassScene
01-25-2007 04:04 PM
