h22a1 civic start up problems please help!
Okay so I have a 1999 civic dx that had a h22a! Swapped in it. I've had for about 6 Months and it was running just fine until the wiring harness got kicked and my car got thrown into limp mode(whoever did the wiring harness did a bad job on it and its kinda jank). I got the limp mode to go away but a cel 21 was on for vtec solenoid. I figured something in the harness got loose that caused the cel so I messed with the harness for a min and the cel went away and the car was running fine. Ten min later I came back and then it just wouldn't start. I replaced the plugs and checked for spark, I got no spark so I thought it might be the distributor. I changed the cap, rotor and the icm but still nothing. Idk what to do. I've checked all fuses, and my fuel pump is dtill working so the main relay is fine. Could it be a ground for the dizzy? If so where is it located? Any help would be awsome. Thanks
LD McCool
02-01-2017 04:39 PM
raceready1320
01-30-2008 12:40 PM
