Help identifying an engine swap
Old Feb 2, 2014 | 11:43 AM
mstarr21's Avatar
Default Help identifying an engine swap
First off I live in California. My sister bought a swapped civic from a guy out of state and now we are trying to get it through the smog process. We've got a few things to change out for smog, but the main problem is that it has a CEL and I cannot find the connectors to read the code. I have quite a bit of experience with cars but not with Hondas, especially with swapped ones.
Car info:
1993 Civic EX 2dr
5 speed
Supposedly has some sort of B16 swap
ECU #: 37820-P72-A01 (so 94-00 Integra ECU??)
I would post a picture, but I'm a new user and I can't.
I'm happy to search, and I have, but I am getting confused with all the engine designations. What should I look for initially?
Old Feb 2, 2014 | 11:46 AM
Tyler Dirden's Avatar
I am Jack's...
Default Re: Help identifying an engine swap
Two pin connector behind glove box.
Look for engine series stamp where trans and motor meet in the front.
Old Feb 2, 2014 | 02:40 PM
lazlong's Avatar
How to check for CEL: http://check-engine-light-codes.blog...retrieval.html
Engine designation:
Old Feb 2, 2014 | 03:24 PM
mstarr21's Avatar
Thanks guy, will check that and search it first. I cannot find that 2-pin connector anywhere, which is throwing me a little bit. Not sure if the PO who did the swap hid it somewhere different or not.
Old Feb 3, 2014 | 01:38 AM
HondaPartsHero's Avatar
Technical Hero
If you can't find it you can ground pin D4 on the ECU and pull the codes that way
http://technet.ff-squad.com/wiring.obd1.htm
Douglas Amaya
Mar 10, 2019 08:05 PM
CustomCivic
Aug 29, 2008 05:32 PM
wuclan
Feb 7, 2004 04:54 PM
91hondacrx
17
Jan 6, 2003 05:21 PM
IgniteTeg
Jun 4, 2002 08:44 PM
