my H2B power output? and drivetrain loss on dyno?
Ive built my h2b in a dc2 chassis
Now I dont know what type of power I SHOULD be getting
Spec is
Stock h22a7 accord type r engine
Cold air intake
H2b tri y manifold
h2b qsd baffeled sump
Custom 2.5" exhaust system with decat
S80 98spec gearbox 4.7 final drive
Power steering delete
Balance shaft removed
Toda lightweight flywheel
6puk clutch
So how much WHP should I get out of my setup after a good long tune on a hondata s300 ecu
Ive already had it dyno'd but I think its high just wanted to check here first
And what percentage of drivetrain loss should I be loosing?
Spec is
Cold air intake
H2b tri y manifold
6puk clutch
Re: my H2B power output? and drivetrain loss on dyno?
Dynos dont measure crank/flywheel horsepower they measure wheel horse power.
Now stop beating around the bush and post your results and a dyno graph
Lol I know that, just that everyone here in the uk go by engine horse power, im more into whp
But mate you hit the nail on the head! Very good guess
230.3 whp
177.2 tq
We even done a transmission loss check by doing a negative run on the dyno (coastdown run) which showed im losing 20.5% through the drivetrain.
Would you day these figures are realistic or over estimated on the dyno?
Al get a picture up in a min
230.3 whp
177.2 tq
Given the setup, sounds reasonable to me. Keep in mind that dynos don't all read the same. Mustang dynos are known for reading "low". If you put down a number on a mustang dyno then went down the street to a dynojet or dyno dynamics, ect., you could see a 30whp pick up(just a guess based on your setup). Many times people get wrapped up in dyno numbers and forget that they(dynos) are nothing more than a tuning tool. Trap speed is a better indicator of whp.
Yeah I know, every dyno reads different, mines a dynocom, only had it a a month or so still getting used to it, ive set it up to be as accurate and realistic as possible, thought it was reading high at first, people around here say that I cant get that much on the setup ive got, and I know thats what I was supposed to get, thats what h2b's are known for.
Next step is 12-5-1 high comp pistons and stage 3 cams and valvetrain, and 3inch exhaust!
Im aiming for 300... you think al get that?
torque seems alittle high, my h23a put out around 175ftlbs.im sure if you look around you'll see that 90mm h22s are putting out around 10ftlbs less.
yea that dyno is reading pretty high u should be in the 210-220 range with ur setup unless u just got blessed with a crazy healthy out the box motor which is possible... and 300 is hard to get with the set up u want
