b18b swap 95 civic no fuel! help!
what's up Honda tech
I'm very new to the Honda world so forgive my lack of knowledge and I'm also a shitty searcher! I recently acquired a 95 Honda civic vx with an b18b1/vtec swap heavily modified by previous owner idk how to identify what cylinder head to be honest b16 or b18c??, engine had rod knock, got the car for dirt cheap, so far I've done a jdm b18b swap all stock, I acquired 99 ls engine harness, 2 or 3 plugs have no places to be plugged in btw, the car came with an 37820-p28-a01 ecu and had a hondata s200 wired or chipped into it, after replacing the engine I got an 37820-p75-a01 obd1 94 ls ecu hopping I would just have to plug it in and start her up but that was not the case, my injectors are not getting signals to deliver fuel. the engine runs if I spray carb cleaner in the intake, I know my timing is correct cam gear line all line up and I'm getting spark. my questions are:
-can I use the distributer that came with the engine? my 99 ls engine harness plugged in I'm getting spark correct me if I'm wrong
-can I use the 99 ls engine wiring harness or should I get rid of it?
-is my ecu the correct ecu for the engine? upon research I got an 94 obd1 ecu I'm pretty sure the engine is obd2 from valve cover
-as far as fuel delivery I have voltage at fuel pump and also have fuel pressure
-do I need different injectors?
basically tell me how can I get it running again
I would really appreciate it
thank you Honda tech
