Obd1 gsr swap into 94 civic si
So I am wanting to swap a usdm gsr motor from a 95 gsr into my civic 95 si.
So far I know I need his
Motor/trans
Axles
Throttle cable?
Linkage
Ecu
All I should need is
lower rad hose
Iab/knock wired
Del sol vtec/crv ac bracket
Rear t bracket
Will the gsr engine harness plug up to my shock tower harness (wanna keep my single cam I've for when I sell the motor)? Am I forgetting anything?
Motor/trans
Axles
Throttle cable?
Linkage
Ecu
lower rad hose
Iab/knock wired
Rear t bracket
Re: Obd1 gsr swap into 94 civic si
Motor/trans
Axles
Throttle cable?
Linkage
Ecu
lower rad hose
Iab/knock wired
Rear t bracket
Motor/trans
Axles
Throttle cable?
Linkage
Ecu
lower rad hose
Iab/knock wired
Rear t bracket
i have ac and want to keep it. i wanted to keep my stock harness with the z6 so i can sell my z6 swap with harness, mounts, and ecu all that. his motor runs fine and i was just gonna keep his harness hooked up and plug it in, and then run the wires for knock and iabs.
i think if i use the gsr throttle cable that would be best right? make a bracket for the throttle cable at the firewall
he is gonna do a type r swap obd2 into his teg, so he wont need the harness or throttle cable.
What do you mean make a bracket at the fire wall?
Ok I understand. Yes I'm pretty sure the gsr harness will work. Eg/Dc/delsol are all pretty much the same bays and all that besides a few small things. If you wanted to do it right go to honda and get the b16 del sol throttle cable and bracket. But like I said I have a gsr throttle cable.
Technical Hero
It'll plug up just add the wiring from the shock tower to the ECU for knock and IAB's. I don't believe the exhaust manifold bolts up to the cat correctly so you'll need to get an exhaust shop to adjust it.
https://honda-tech.com/forums/hybrid-engine-swaps-18/definitive-guide-gsr-eg-swap-2976738/
boostincoupe
09-10-2006 08:34 AM
bboylito
04-05-2005 11:49 AM
00ITR-0723
03-11-2004 10:07 PM
