Rear engine mount doesn't fit?!?!
Old Aug 27, 2004 | 12:51 PM
Sound Streamin''s Avatar
Default Rear engine mount doesn't fit?!?!
The rear engine mount that was sent with my b16a doesnt fit the motor. Are the rear mounts on auto engines different from those on manual motors? If so, Im thinking I was sent an automatic mount instead of a manual one. What kind of car would I be able to swipe a mount off of? Does the DOHC delsol have the same mount? Any help would be appreciated.
Modified by Sound Streamin' at 4:03 PM 8/27/2004
Old Aug 27, 2004 | 02:31 PM
Doctor CorteZ's Avatar
Default Re: Rear engine mount doesn't fit?!?! (Sound Streamin')
could you give a little more info ?
like what kind of car you're working on...
Old Sep 3, 2004 | 10:24 PM
It's a 95 Hatch. I went and got the 99-00 Si rear mount, which I was told would work, and it's too friggen short. Which mount do I need? It's a JDM b16a too btw.
Old Sep 5, 2004 | 09:52 PM
97mini-me's Avatar
Default Re: (Sound Streamin')
Which b16 do you have? If it is the SIRII then you shouldn't have any problems. If it is the 1st gen b16 then you will have to buy a Del Sol b16 rear mount. It is different from the 99 SI mount.
Old Sep 9, 2004 | 12:30 PM
boomslang's Avatar
99-00 Si won't work.
You need a 94-01 Integra rear mount.
Old Sep 17, 2004 | 02:02 PM
Turns out I did need the 94-01 Integra mount. But my buddy took the cut mount that was on the engine and my stock mount and made me one.
Old Sep 17, 2004 | 09:48 PM
fabworxs's Avatar
for the $60 I'd just go buy a 1994-2000 Integra mount.
Old Sep 18, 2004 | 05:16 PM
brian g's Avatar
Default Re: (everyone)
Call it a bracket instead of a mount everyone, mounts insulate, brackets connect to the mounts.
The 96-00 Civic and 94 Integra rear mounts are interchangeable. Of course you guys are talking about brackets, which aren't interchangeable.
brian g
CincyCichlids
Oct 6, 2009 04:21 PM
dem0nk1d
Nov 21, 2008 09:44 AM
Greg456
Apr 8, 2004 09:49 PM
92civeg
Feb 15, 2004 04:05 AM
