jdm motor!!! us or jdm ecu?!?!?!?!?!? help!
whats up guys i bought a jdm motor and i swapped it into my civic, the motor is a 99 jdm engine, but im still using an obd1 usdm ecu, should i change it to the jdm ecu? would it run better?
my vtec isnt engaging because my coolant temperature senor is missing too....this sucks....no vtec
Re: jdm motor!!! us or jdm ecu?!?!?!?!?!? help! (MURDERHATCH)
use the 94-95 usdm gsr ecu or I can have a P28 chipped with a good gsr program with IAB control. I have dynoed it back to back against a P72 and it was better low rpm wise and make same HP top end, can also move rev limit.
ivan93egreppin210
Engine Management and Tuning
10-11-2009 12:45 PM
Real JDM P72 Gsr Ecu????? what codes lets you know if its really a JDM ecu or how to tell the differ
Kangolbrand
01-24-2006 04:10 PM
