No presure in the clutch pedal after completing swap?
I just finished swapping a d16z6 into my cx, engine started with the first turn but when i went to go bleed the clutch i dont have any presure at all. It just sinks back to the bottom. I have bleed my clutch and brakes plenty of times so im positive that im doing it right. I have no idea whats going on and i already went through a full bottle of fluids there aren't any leaks either, the only thing i can think of is when i was putting the tranny back on the engine im not sure if i put the throw out bearing back on, could this be the problem?
cliff note:Getting no presure in the clutch pedal, tried bleeding the clutch but it
didnt do anything, dont really remember if i had put the throw out bearing on when i put the tranny back on the engine, could this be the problem?
Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">have someone step ont ehclutch and see how far the slave cylinder pishes out.</TD></TR></TABLE>
ill give that a try, thanks
.I.Need.Money.
08-16-2008 04:03 PM
