throttle cable help! please
New User
I have a 94 civic ex that used to be an auto and was converted to manual with a GSR motor.
I have now swapped my own B18C1 into the car and can't figure out how to mount the throttle cable to the pedal? I am using an ITR throttle cable, and it seems that there is a bracket missing. although it does pull at the throttle and open the TB about 2/3 of the way. I need to tighten it to get it to pull all the way. Otherwise how do i connect the throttle cable to the pedal?
also while i am at it. what is the size used for the heater hoses? 5/8 s? also what piece do those of you using a map sensor use to plug off the TB opening?
Mixmasta
07-14-2008 06:30 AM
