Radiator hose for EK swap?
You can upgrade to an aluminum radiator, or just use hose clamps and tighten the end on the radiator down really tight. You could also check the size on the 99-00 Si hoses, but I'm not sure if the Si radiator had larger in/outs than the other 96-00 Civics or not.
Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">I'm not sure if the Si radiator had larger in/outs than the other 96-00 Civics or not.</TD></TR></TABLE>
Yeah, it does. It's the same as the gsr hoses.
Re: (deSigi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote"> You could also check the size on the 99-00 Si hoses, but I'm not sure if the Si radiator had larger in/outs than the other 96-00 Civics or not.</TD></TR></TABLE>
Si has larger hoses than other model civics. I have Si hoses and fluidyne on my b18c.
Re: (97civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx »</TD></TR><TR><TD CLASS="quote">Cant u also use the Del Sol SI upper and lower rad hoses?</TD></TR></TABLE>
I think you can.
I think you can.
Re: (deSigi)
I'll probably get flamed for saying it or people will say it's ghetto, but honestly don't knock it until you try it. You can actually reuse the D series upper and lower radiator hoses. Depending on the engine you install you will usually need to trim the hoses to fit. I used this as a short-cut method one time on a friend's swap but now I reuse the D series hoses nearly all the time. You just need to take a heatgun and heat up the end of the hose on the engine side. Use some WD-40 or oil on the water neck on the motor and they should slide right on without much trouble. This prevents the typical B series hose to SOHC radiator leaks and what not.
Guest
Posts: n/a
Re: Radiator hose for EK swap? (kitchale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">You can upgrade to an aluminum radiator, or just use hose clamps and tighten the end on the radiator down really tight. </TD></TR></TABLE>
thats exactly what i did and have absolutely NO problems. you just gotta make sure the clamp is tight as hell. i think this is the easiest and cheapest way to fix the issue
Si-Yaaa!
Northern California (Sales)
10-08-2010 12:07 AM
Draggin99Si
12-29-2005 11:54 AM
