AIB question ?
Old Aug 18, 2004 | 04:39 PM
type-t's Avatar
Default AIB question ?
i just finish my h22 swap into 92' accord...i started the engine and it idles really really bad...i dont have my AIB connected to the p13 ecu yet because it has 2 wires and i dont know which wire plugs to pin#A17...could this be causing the problem? i also did not connect the o2 sensor yet and i know that it gives me a check engine light.
one more question...how do i do a diagnostic test on thruogh the ecu?
Old Aug 18, 2004 | 04:49 PM
KTeller8's Avatar
Default Re: AIB question ? (type-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-t &raquo;</TD></TR><TR><TD CLASS="quote">i just finish my h22 swap into 92' accord...i started the engine and it idles really really bad...i dont have my AIB connected to the p13 ecu yet because it has 2 wires and i dont know which wire plugs to pin#A17...could this be causing the problem? i also did not connect the o2 sensor yet and i know that it gives me a check engine light.
one more question...how do i do a diagnostic test on thruogh the ecu?</TD></TR></TABLE>
you talking bout the secondary butterflys?
one connect the O2 sensor, it reads air and fuel mixtures.. that will make you run like el poo poo~
plug in your o2 sensor, then reset the batter,... pull the codes:
2 ways to pull codes, either use a code reader or go to autozone/pep boys let them use it.
or under your dash there is athe service connector.. (search on ht if you dont know what i mean) put a wire put in it to connect the connectus
should look like this:
U
like that, it will make the CEL flash, count the flashs to get your code:
long flash = 10
short flash= 1
good luck, do more searching on here for codes, code pulling
Old Aug 18, 2004 | 07:08 PM
type-t's Avatar
Default Re: AIB question ? (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">
what are the secondary butterflys?
U
long flash = 10
short flash= 1
good luck, do more searching on here for codes, code pulling</TD></TR></TABLE>
Old Aug 19, 2004 | 06:13 PM
type-t's Avatar
U
long flash = 10
short flash= 1
when you say it will make me run like el poo poo...do you mean hooking it up will make me run that way or not hooking it up will make me run that way?
jaha-crx
Sep 24, 2008 09:37 AM
turcasso
Jan 5, 2008 02:52 PM
ef8-dc2619
Jan 31, 2007 04:29 PM
PhatwhipsJDMkits
Nov 28, 2004 09:31 AM
Maverick77
Nov 22, 2002 07:50 PM
