B20 ECU problems!
Old Aug 21, 2004 | 10:12 AM
JDMIntegR1's Avatar
Default B20 ECU problems!
OK heres the problem, i have a 90-91 CRX Si which had a JDM b16 obd0 wire harness, my hommie blew the motor so i got a year 2000 b20. Heres the problem, i got the swap in everything is good but the problem is the ECU, i was told that i can use my p73 b16 ecu with the b20 if i configure it with my V-tec controller, changing the fuel curves and disable the v-tec. I need to know if anyone knows how to program the v-tec controller to control the b20 using a p73 ECU... its possible but if this **** takes to long anyone have a 90-91 LS ECU for free or for sale!
Old Aug 21, 2004 | 12:48 PM
wreckedmyteg's Avatar
Default Re: B20 ECU problems! (JDMIntegR1)
I'd use the LS ECU. The VTEC ECU is going to throw codes like it's going out of style.
Old Aug 22, 2004 | 06:34 AM
turboimports's Avatar
Default Re: B20 ECU problems! (wreckedmyteg)
Yes I agree..Just use the LS ECU, plug and play if your OBD matches.
-Lor
Cass_EF
Sep 24, 2016 01:28 AM
troppop
Jul 30, 2006 04:04 AM
B18PoweredCivic
Mar 14, 2005 09:13 AM
1hotcivicSi
Feb 19, 2004 07:12 AM
bdicustoms
Nov 6, 2003 05:20 AM
