h22a iab help.
i am swapping an h22a into my 94 accord, and i am using the accord harness. I know the iab has two wires, one that is power, and one that is a signal going to the ecu. however, i never had a prelude harness, so i am not sure which pin on the iab plug is which. is the pin closest to the block the power, or the signal. (or for any of you with a prelude harness, which pin has the pink wire coming off it? Thanks, Ben
killingtwobirds
May 8, 2007 12:54 PM
