b18c-R LS
Old Aug 31, 2004 | 03:21 PM
benjamin's Avatar
Default b18c-R LS
hey guys
I have recently swaped a obd2 96 b18c-R into my obd1 94 integra LS. The reson for obd2 engine is because it was originally bought for a obd2 99 gsr sedan with no engine.
This is my first engine swap, I was confident in all the mechanical stuff because the engines are basically the same except wiring. My friend told me that if I was to do the swap he would be able to do the wiring for me. The engine is in and everthing is hooked including the wiring.
When I check for cel codes it is just constant light and when i try and start it up it turns over but does not fire. I was wondering if anbody has any wiring info so i could check me friends work, or possibly send it out to hasport.
thanks in advance
Old Sep 1, 2004 | 03:47 PM
benjamin's Avatar
Default Re: b18c-R LS (benjamin)
anyone?
Old Sep 1, 2004 | 09:32 PM
Slopoke's Avatar
So what ecu are you using?
Just start trouble shooting with the normal things.
Can you hear the fuel pump priming when you turn the ignition on?
Do you have spark?
Is the cam timing correct?
Is the ignition timing correct?
Old Sep 2, 2004 | 06:20 AM
benjamin's Avatar
Default Re: b18c-R LS (Slopoke)
I am using the original ecu from my 94 LS, I have not replaced it. The fuel pump is priming, and I am unsure of the others because I am away at school but will be home to check this friday night.
DC4_Dad
Aug 15, 2018 08:59 AM
Mattcuzko
Engine Management and Tuning
Mar 12, 2011 11:12 PM
ipimpgarland
Mar 2, 2004 05:34 AM
3minburnout
Sep 16, 2003 08:30 PM
Dokta
Aug 6, 2002 09:40 PM
