suggested spring rates with H22 EG.
what would you guys suggest for spring rate on a h22 EG hatch? i have herd of people running 12F and 10R, but what would you guys suggest or run?
I am looking at some omni's if that matters.
Re: suggested spring rates with H22 EG. (enigma94)
I just put 400lbs Front And 500lbs Rear and i Love it. There with konis and if i turn it to firmest they are very stiff but tolerable, and ride real smooth set soft. I wanted a set up for Drag and street.
All together came to $800 maybe the best bang for your buck.
stock. It wll be fine for you unless you are auto-x'ing or road racing. If you are doing either of those, you probably wouldn't be asking this question.
I am runnin 400lb up front and 350lb in the rear with kyb agx's. Real nice ride on all settings. However if u are going to drag occosionally I would recommend a higher spring rate in the rear. Something like 450-600lb's! Good luck!
Re: suggested spring rates with H22 EG. (1SICJDM)
"This is a completely open question. Quite frankly, if you're blindly asking this question, you probably dont need custom rates and brings us back to the original question, "Should I get coilovers or springs?" and you probably would be better off with one of the many street kits from Eibach, Neuspeed or H&R, or just get the preset vehicle specific kit from GC. " - FAQ Site
As many people have said before, it depends on you, the driver, it's like telling you what you're favorite pizza is.
i didnt like hwo stock springs felt with an h22a, right now i run 450 in front and 350 in rear though i would liek to switch the springs for now (coilover sleeves), until i can get something stiffer in teh rear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enigma94 »</TD></TR><TR><TD CLASS="quote">i have herd of people running 12F and 10R, but what would you guys suggest or run?
I am looking at some omni's if that matters.</TD></TR></TABLE>
12f 10r...??... what?
omni's?.. what?
where have u been reading?
omni's?.. what?
Re: suggested spring rates with H22 EG. (jmayhew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmayhew »</TD></TR><TR><TD CLASS="quote">i ordered 9k/7k (front/rear) aprox..500/400
hopefully it will be a decent setup.
That should be more than enough for any street setup.
so with these spring rates in mind...it is possible to just call a company upon ordering and tell them u want a certain spring rating and they will package them, or do you need to ask for a certain type vehicle? ive always heard that if running coilovers with the h22 the integra gsr springs are very good and allow more weight.
Re: (h22apwrdcivic)
It's all about mainly what YOU want out of the car. Nice daily driving, or hardcore on the track.
I'd say Koni's and H22 Civic rated Ground Controls..
Re: (h22apwrdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22apwrdcivic »</TD></TR><TR><TD CLASS="quote">so with these spring rates in mind...it is possible to just call a company upon ordering and tell them u want a certain spring rating and they will package them, or do you need to ask for a certain type vehicle? ive always heard that if running coilovers with the h22 the integra gsr springs are very good and allow more weight.</TD></TR></TABLE>
Depends on the company. With Ground Control for an additional 39 bucks u can have any spring rate u want. U tell them the car/motor u have and if u dont know what u want they will suggest something. Just tell them what car u have and what struts u will be using!
ive got GC with 500F and 400 R now. It rides quite well and very streetable. Personally 400's in the front are just too soft IMO. As far as my rear spring rate I might be going to a 450-500 spring rate. I have to due some suspension tuning, counter weighting and things like that and see where I am at. Right now though the car understeers. SO I may or may not get the understeer dialed out. If not I will be running 450-500's.
