hard to shift into 4th
Old Aug 20, 2004 | 01:04 PM
dohcdelsol93's Avatar
Default hard to shift into 4th
Just did a b18b swap in my 93 del sol si using a b18a tranny(91). Has new clutch/pressure plate/t.b. It's hard to shift into 4th gear sometimes, kind of sparatickly. Sometimes when shifing @5,000 rpms and others @2,500. I have new mtf fluid, i've used both valveoline 10-30 and honda mtf. Theres no grinding at all, just hard to put into gear. Seems to be easy when I'm not moving but has been hard to get in a few times I am using the del sol dohc vtec linkage. any suggestions?
Old Aug 20, 2004 | 10:46 PM
93hatchin's Avatar
Default Re: hard to shift into 4th (dohcdelsol93)
make sure you put enough fluid in it..... if not that then its gotta be a linkage. g/l
Old Aug 21, 2004 | 04:03 AM
Default Re: hard to shift into 4th (93hatchin)
I changed the fluid last night, for some odd reason it seemed to make it shift normally no stiff shifting. I had enough fluid to begin with, this is the third time i've changed fluid, i guess it might have been gumed up from sitting in the junkyard for several years, the orginal fluid i removed from the tranny was really nasty.
Old Aug 21, 2004 | 08:36 AM
type-t's Avatar
i have a similar problem....i changed the clutch fluid and tranmission fluid..but its very hard to shift even on first..i have to jam the damn thing in wtf is it
Old Aug 21, 2004 | 09:03 AM
Default Re: hard to shift into 4th (type-t)
being that your having probs with all gears I'd lean toward clutch/pressure plate/ throw out bearing. Is there any grinding when you put it in gear?
Old Aug 21, 2004 | 03:36 PM
type-t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">being that your having probs with all gears I'd lean toward clutch/pressure plate/ throw out bearing. Is there any grinding when you put it in gear?</TD></TR></TABLE>
yeah it grinds
Old Aug 21, 2004 | 09:16 PM
93hatchin's Avatar
what colors did you find in the old fluid most likely it is the bronze blocker ring.
Old Aug 22, 2004 | 09:06 AM
type-t's Avatar
Default Re: (93hatchin)
the fluid was in good shape...how do you replace the bronze blocker ring..i've never heard of it. thanks
Old Aug 23, 2004 | 04:33 PM
93hatchin's Avatar
i goes in between the synchros. if you have gold flakes in the old fluid it was the bronze ring. if it was cloudy then it is your actual synchros. is it calbe tranny or hydro?
Old Aug 23, 2004 | 09:54 PM
type-t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hatchin &raquo;</TD></TR><TR><TD CLASS="quote">i goes in between the synchros. if you have gold flakes in the old fluid it was the bronze ring. if it was cloudy then it is your actual synchros. is it calbe tranny or hydro?</TD></TR></TABLE>
i think its cable..its 94 jdm h22a manual it should be cable....
PA07
Transmission & Drivetrain
Oct 11, 2014 06:37 AM
meangreenEG
32
Jun 28, 2007 11:09 PM
danman3323
Feb 25, 2005 06:08 PM
civic_speed99
Jan 20, 2005 06:39 PM
DarkShadow
Oct 7, 2004 05:24 PM
