Need help with b16 swap
Old Aug 19, 2004 | 07:25 PM
nauticapinoy's Avatar
Default Need help with b16 swap
I tried searching but no luck. I have a 97 civic hatch dx. I got a 2000 b16 swap out of an si. I dont have the harness for the b16 and I'm having probs with using my stock harness fitting with the b16. What can I do? Am I able to use the stock dx wiring harness? Or do I need a b16 wiring harness? And also the Ecu code for the Si b16 is P2T right? Just wanna make sure. thanx.
Old Aug 19, 2004 | 07:28 PM
Boosted EP's Avatar
Default Re: Need help with b16 swap (nauticapinoy)
check out jdmshit.com
Old Aug 20, 2004 | 11:44 AM
Anyone else?
Old Aug 22, 2004 | 06:42 AM
turboimports's Avatar
Just go out and get a usdm b16a2 ecu and wiring harness...If I remember right, they both will just bolt up to your chassie, and engine. Seems pretty easy.
-Lor
Old Aug 22, 2004 | 06:43 AM
Default Re: Need help with b16 swap (turboimports)
make sure you get an obd2 usdm...if you go for jdm, watch out for obd compatibility.
-Lor
Type-R32
Oct 24, 2008 08:09 PM
crxrider07
May 29, 2008 11:56 AM
skateman190
Apr 12, 2007 04:45 AM
h0tsihatch
Mar 28, 2004 08:25 AM
