87 Si w/ B20BVTEC wiring harness "SWAP"
The Boot
87 Si
B20BVTEC
Going to be swapping that engine into my 91 STD.
Can i take the ENTIRE harness out of the 87 and swap that with the engine without any modification?
I am trying to avoid all the wiring woes that I am going to encounter modifying the STD harness.
Modified by Smokinsax at 3:55 AM 8/26/2004
B20BVTEC
Re: 87 Si w/ B20BVTEC wiring harness "SWAP" (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax »</TD></TR><TR><TD CLASS="quote">
You'd just be trading some wiring problems for worse wiring problems. Modify the Std harness.
brian g
brian g
The Boot
Re: 87 Si w/ B20BVTEC wiring harness "SWAP" (brian g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g »</TD></TR><TR><TD CLASS="quote">You'd just be trading some wiring problems for worse wiring problems. Modify the Std harness.
brian g</TD></TR></TABLE>
W W
from the man himself...thanks for the advice!!!!
W W
hasport has what you need ask brian they have digrams if your skilled enough you can do it yourself. he might give you the digram
Re: 87 Si w/ B20BVTEC wiring harness "SWAP" (bossman032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g »</TD></TR><TR><TD CLASS="quote">You'd just be trading some wiring problems for worse wiring problems. Modify the Std harness.</TD></TR></TABLE>
I'll second that. Definitely reuse the DPFI harness, do the MPFI wiring and add any other needed wiring to it (VTEC, knock, etc.). A lot of people make the MPFI wiring sound like it's hard but honestly it's really simple and not too involved. You'll be able to salvage the injector clips and wiring from the 87 Si harness to use on the DPFI harness.
streetracerof06
09-02-2005 07:16 AM
