CEL no V TEC any relation?
Old Aug 25, 2004 | 04:25 PM
type-t's Avatar
Default CEL no V TEC any relation?
i have a check engine light due to no oxygen sensor connected to the ecu...
"This question is only for those that no the correct answer...please dont assume"
will this cause my v tec not to kick in? and if not..what else can cause that? thanks
++++++++++++++++92' accord jdm h22a swap++++++++++++++++++++
Old Aug 26, 2004 | 01:51 AM
poison's Avatar
Default Re: CEL no V TEC any relation? (type-t)
No, a malfunctioned or unhooked O2 sensor will not cause VTEC to stop functioning.
Check your oil level, clean the VTEC solenoid screen.
And not to be an *** -- but I certainly hope those mods in your sig aren't ones you are planning.
=X
Old Aug 29, 2004 | 06:05 PM
type-t's Avatar
Default Re: CEL no V TEC any relation? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">No, a malfunctioned or unhooked O2 sensor will not cause VTEC to stop functioning.
=X</TD></TR></TABLE>
lol...whats wrong with my futer mods?....but anyways am i supposed to ground the black cable coming from the vtec solenoid?
Old Aug 30, 2004 | 10:00 AM
the_crowbar's Avatar
I assume you are talking about the H22 in your accord, but on a friends civic D16y8 the VTEC solenoid connects to the ECU. The VTEC oil pressure has two connections. (If I remeber right one of them is ground. Would have to look to be sure.) On my H22A4 Prelude the VTEC solenoid is one wire as well; not sure about the oil pressure on that one.
On the D16y8 a missing/unhooked/nonfunctional O2 sensor did not prevent the ECU from activating VTEC.
HTH
the_crowbar
Old Sep 2, 2004 | 08:38 PM
type-t's Avatar
Default Re: CEL no V TEC any relation? (the_crowbar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_crowbar &raquo;</TD></TR><TR><TD CLASS="quote">I assume you are talking about the H22 in your accord, but on a friends civic D16y8 the VTEC solenoid connects to the ECU. The VTEC oil pressure has two connections. (If I remeber right one of them is ground. Would have to look to be sure.) On my H22A4 Prelude the VTEC solenoid is one wire as well; not sure about the oil pressure on that one.
HTH
the_crowbar</TD></TR></TABLE>
it works..damn what a difference!...i skreetch tires even on 3rd gear
preludetospeed
Feb 4, 2007 08:50 PM
HUYNH
Aug 2, 2006 01:00 AM
Sic_DA_Nine
Jul 9, 2006 07:41 PM
sikek
Jul 27, 2004 09:56 AM
sctan15
Aug 23, 2003 01:51 PM
