Check Engine Light - Code 17, VSS
Old Aug 24, 2004 | 04:46 AM
7rrivera7's Avatar
Default Check Engine Light - Code 17, VSS
I'm running a 1st gen B16a with a Hondata ODB0 PR3 on a CRX. I'm getting a random check engine light every now and then - code 17, VSS (vehicle speed sensor). Can someone point me in the right direction as to where this sensor is located?
Old Aug 24, 2004 | 05:53 AM
Ransom's Avatar
Default Re: Check Engine Light - Code 17, VSS (7rrivera7)
its located on top of the tranny back towards the firewall.
Old Aug 24, 2004 | 06:19 AM
7rrivera7's Avatar
Default Re: Check Engine Light - Code 17, VSS (LudeSH)
Is this the cable that goes to my speedo? This is mechanical...
Old Aug 24, 2004 | 10:37 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7rrivera7 &raquo;</TD></TR><TR><TD CLASS="quote">Is this the cable that goes to my speedo? This is mechanical...</TD></TR></TABLE> The drive gear is on the tranny but the actual VSS in part of your cluster. Make sure the speedo drive isn't loose.
Old Aug 25, 2004 | 04:39 AM
7rrivera7's Avatar
Default Re: Check Engine Light - Code 17, VSS (APEX CRX)
Thanks APEX! That was it...
Old Oct 31, 2004 | 06:05 PM
gabspeed's Avatar
im getting the same problem on my 99 dx with obd1 convertion where is this speedo drive? so i could check if its loose? im lost or the VSS for that matter thanks for the help
Old Nov 2, 2004 | 06:03 AM
gabspeed's Avatar
Default Re: Check Engine Light - Code 17, VSS (gabspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabspeed &raquo;</TD></TR><TR><TD CLASS="quote"> im getting the same problem on my 99 dx with obd1 convertion where is this speedo drive? so i could check if its loose? im lost or the VSS for that matter thanks for the help </TD></TR></TABLE>
any help here?? anyone?
Old Nov 2, 2004 | 06:25 AM
sullenht's Avatar
n the back of the cluster thats the cable that goes from the VSS on the tranny to the back of the cluster in the dash
Tank_EM2
Honda Civic (2001 - 2005)
Jul 1, 2014 03:28 PM
hatch_kidb18b1
Aug 14, 2009 02:40 PM
accord20o1
Feb 13, 2008 05:36 PM
QuarterMileMaster
Aug 5, 2004 07:43 PM
.Noah Fecks
Jun 26, 2003 11:21 AM
