h22 hatch handling
Old Aug 23, 2004 | 09:49 PM
H22A_HB
Guest
Posts: n/a
Default h22 handling
i have an h22a in my 93 hatchback but it has very poor handling what can i do to make my handling good i want something that i will have great handling
Old Aug 23, 2004 | 09:59 PM
Kal's Avatar
Kal
Default Re: h22 handling (H22A_HB)
coilovers? new LCAs, tie bars...
various bars to stiffen the chassis.
Old Aug 23, 2004 | 10:00 PM
Nikoli's Avatar
c'mon take a long hard guess about this question? what do you think gives you better handling
Old Aug 23, 2004 | 10:35 PM
SunShine287's Avatar
Still... when you plop a larger motor in, you funk things up a bit...
What's your weight dist? You could get the stiffest springs/shocks available but it still wont feel like an evenly balanced car.
Then again, is the h22 really that much heavier than the methinks b16 that was originally in there?
::shrugs::
Old Aug 23, 2004 | 10:52 PM
H22A_HB
Guest
Posts: n/a
Default Re: h22 handling (SunShine287)
well i really dont remember what it had in there but when i first got my motor they told me it was 450 pounds
Old Aug 23, 2004 | 10:55 PM
v4lu3s's Avatar
RTFM
what suspension is on the car right now?
Old Aug 23, 2004 | 10:57 PM
Behan's Avatar
I'm pretty sure someone makes a set of springs for the h22 swapped hatch. However i can't remeber the companys name. You would probably have better results in the hybrid or civic forums.
Asking a bunch of prelude drivers for advice on your civic's handling, probably won't provide you with the best advice.
Good Luck
Old Aug 23, 2004 | 10:59 PM
H22A_HB
Guest
Posts: n/a
Default Re: (v4lu3s)
i have tokico illmumina with coilovers
Old Aug 23, 2004 | 11:07 PM
H22A_HB
Guest
Posts: n/a
Default Re: (H22A_HB)
also my tranny has lsd i have coilovers but is not like top of the line
Old Aug 24, 2004 | 05:00 AM
Quick99Si's Avatar
Number 1, tires.
Prelude spring rates up front, this is crucial. H22's weigh ~150lbs more than a B16 (and around 90# more than B18C) which I suppose should be similar in weight to a D16.
I guess a rear sway bar and FSTB should help with understeer too.
Adi
Old Aug 24, 2004 | 08:02 AM
93H22ACX's Avatar
Default Re: h22 handling (Quick99Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick99Si &raquo;</TD></TR><TR><TD CLASS="quote">Number 1, tires.
Adi</TD></TR></TABLE>
it is not 150lbs more than a b16....its about half a tank of gas weight difference....taken from this site:
http://honda.hybrids.jp/forum/...sb=&o=
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A_HB &raquo;</TD></TR><TR><TD CLASS="quote">i have an h22a in my 93 hatchback but it has very poor handling what can i do to make my handling good i want something that i will have great handling </TD></TR></TABLE>
mine is in a 93 cx and i have stock suspension....doesnt fell that bad going around corners.....are you doing auto x ?
Old Aug 24, 2004 | 08:40 AM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A_HB &raquo;</TD></TR><TR><TD CLASS="quote">i have tokico illmumina with coilovers</TD></TR></TABLE>
im using illuminas wioth drop zone coilovers, no other suspension mods yet, and run 215/40/17 tires, i can say that handling is much better than stock. i only have about 1 inch of drop though, since too low has always been for looks on the street.
Old Aug 24, 2004 | 11:29 AM
Monkey Fing a Coconut's Avatar
h22 is 35lbs heavier than a b18, and maybe 45 heavier than b16, guy on the civic forum i believe weighed everything while the blocks/trannys were out of his car
Old Aug 24, 2004 | 11:33 AM
Matgallis's Avatar
Default Re: h22 handling (twistedbydezign)
yea but fluid weights were not added, along with the little things. It's more around 80lbs
Old Aug 24, 2004 | 12:23 PM
Daemione's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">h22 is 35lbs heavier than a b18, and maybe 45 heavier than b16, guy on the civic forum i believe weighed everything while the blocks/trannys were out of his car</TD></TR></TABLE>
Yeah, there were so many things missing from that comparison it was ridiculous.
Old Aug 24, 2004 | 12:24 PM
lOOkatme's Avatar
maybe you should run a staggard tire set up....like 225's in the front and 205's in the rear....get some of the oversteer characteristics back.
and play with sway bar sizes.
Old Aug 24, 2004 | 02:05 PM
Quick99Si's Avatar
Mine come from a source who weighed the entire drivetrains out of the car as well, wet I assume.
The list goes as follows...
b16a 310#
b18c 370#
h22a 470#
Physically larger engine, longer deck height, heavy *** dual runner intake manifold, heavier clutch/flywheel, huge *** crank, closed deck (4th gen), 0.8qt more motor oil heh
No way in HELL that the 2.2 drivetrain weighs ~35-50lbs more than a B16 (half tank of gas). I'd bet he neglected to reinstall the battery, powersteering system, radiator, a few mounts here and there, as well as the all important FLUIDS.
Adi
Old Aug 24, 2004 | 02:13 PM
PreludeRacer023's Avatar
if you really want good hadling, get a very good set of coil overs and have your car corner weighted...this can change the bais on your car from front to rear very effectively, its more expeinsive but well worth it
Old Aug 24, 2004 | 02:23 PM
v4lu3s's Avatar
RTFM
Default Re: h22 handling (Matgallis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis &raquo;</TD></TR><TR><TD CLASS="quote">yea but fluid weights were not added, along with the little things. It's more around 80lbs</TD></TR></TABLE>
how much les oil and coolant do a b18 or d16 take than an h22a? i mean 1 quart of oil and half a gallon of coolant at most wont be a huge weight diff...
Old Aug 24, 2004 | 05:59 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: h22 handling (v4lu3s)
kinda stupid question but do you have power steering? A lot of people skip on the p/s to "lose weight" but it'll help and you won't look like a complete idiot in parking lots trying to maneuver.
Old Aug 24, 2004 | 08:07 PM
H22A_HB
Guest
Posts: n/a
Default Re: h22 handling (PreIudeSI)
no i dont have power steering
Old Aug 24, 2004 | 08:21 PM
sharkcohen's Avatar
Why is this in the Prelude forum :confused:
Old Aug 24, 2004 | 08:34 PM
blackdelslo's Avatar
Default Re: h22 handling (sharkcohen)
haha h22 is SOOOOO heavy according to you guys but it still makes your b16's and b18's cry when it hits vtec.
Old Aug 24, 2004 | 08:45 PM
Kal's Avatar
Kal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">Why is this in the Prelude forum :confused:</TD></TR></TABLE>
i agree.
the hybrid forum will be a better source haha.
Old Aug 24, 2004 | 10:17 PM
H22EKHATCH's Avatar
you should search or post this in the hybrid forum,
but integra spring rates will do the trick.
also Progress makes springs for h22 hatch
and ground control makes coilovers
but seriously search the hybrids forum its been covered 1000X
