obd1 LS swap into obd2 EK...Let me get this straight. help plz
Ok heres the deal I've got a full swap--from axles, to the ECU, altenator, dizzy (obd1 b18b) with everything except the harness. Its going into my 96 civic EX.
This is what I know I need:
obd1 - obd2 jumper harness
99-00 si tranny and drivers side motor mount
Now what the hell else do I need....I've gotten so many different opinions and people telling me different things, I'm sick of it. Just some guidance would be appreciated, thanks.
Re: obd1 LS swap into obd2 EK...Let me get this straight. help plz (NickW)
I assume that your going from the OBD2 to OBD1. So yes you will need a jumper if you plan to use an OBD1 ecu. Also you are going to use your stock engine harness. This is the only one you can use. Extend a few things, use your EX injectors, change the IAT plug, wire the dist plugs using the plugs off of your ex dist and a few other things. You need the rear tranny mount from the 99 si and the side cast iron bracket that bolts to the side of the block on the drivers side from the 99 si also. You need to use b series front lower tranny mount and the lower front block a/c mount. Any other specific question Pm me.
i have the same question obd1 motor/head but the person i bought the car from used that harness but a p75 ecu and obd2 dizzy...my car is running kinda crappy..how do i convert the obd2 dizzy to ob1 and wut ecu do i need..plzzz help!!! kinda a newb
