which water pump !??!?
Old Aug 30, 2004 | 11:03 AM
Egone's Avatar
Default which water pump !??!?
ive searched but couldnt find a solid answer i have a friend who works at honda so i can get parts prettty cheap anways would a civic si water pump and timing belt work on a integra ls motor?? ive heard if i used the water pump and belt together it should work
Old Aug 30, 2004 | 11:56 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: which water pump !??!? (Egone)
your last statement is correct. as long as you use the same b series water pump with timing belt, you'll be fine.
Old Aug 30, 2004 | 06:07 PM
beaterdriver's Avatar
i thought the b18 series timing belt was longer than the b16 timing belt?
i dont know about the water pumps tho
Old Aug 30, 2004 | 06:45 PM
mingbling's Avatar
you can use a civic si water pump on an ls motor, but you will have to use a gsr timing belt since the b16a has a lower deck height than a b18. in short, its a shorter motor, therefore require longer belt.
cincyb20ek
May 5, 2010 04:51 PM
globy123
Aug 8, 2008 08:38 AM
njracer
Jan 10, 2008 05:07 PM
Turbo R
Feb 12, 2006 10:14 PM
1998hondaaccord
Sep 18, 2003 05:00 PM
