need help with a b18c1 swap
Im trying to put a b18c1 in my 96 hatch but im worried about the wiring what exactly will i need to keep any check engine light from popping up
Re: need help with a b18c1 swap (jonjon149)
what model is your hatch? does it have vtec currently? what ecu will u be running? what obd and year is the motor your putting in? as far as wiring goes if your keeping obd2 you should just have to run vtec wires, and i had to change iether my iat or iacv plug from a three pin to a 2 pin. and of course vtec plugs. plugs are cheap u just gotta find someone whos got em. and you will at least need your primary 02 sensor from your old motor (if the new one doesnt have one)
1 Post
use your ek top mounts. you wll need front tranny mount, a/c bracket, rear si bracket. use your stock harness if its vtec and if its not you can either use the stock one and add vtec wiring or get a 96-98 vtec harness. also get a 96-97 gsr ecu
