automatic to manual
Old Aug 28, 2004 | 09:24 AM
nomotor's Avatar
Default automatic to manual
alrite i found this real nice eg hatch for real cheap but its an automatic, my question is if i take it to a shop to get a engine swap will it be the same as if my car was manual? or would they charge me more? thanks
Old Aug 28, 2004 | 11:15 AM
SD350z's Avatar
Default Re: automatic to manual (nomotor)
they will definitely charge you more, cuz some work and parts will be necessary to make it into manual. search "auto to manual" in the civic forum and you'll find most of your answers. some of the things you'll need to buy are ...clutch lines, pedal assembly, master/slave cylinder, shift linkage, center console, manul cluster unless your eg is an ex/si (then the cluster already has rpms), i believe you need a starter also, but not positive...and then some misc parts...
shop around, you might be able to find a shop that wont charge an arm and a leg for the job..or like most HT people here suggests...do it yourself!!!
Jackie Wallace
Transmission & Drivetrain
Mar 10, 2013 04:23 PM
Bobby Rice
Honda Civic (2001 - 2005)
Sep 10, 2010 02:41 PM
itrcrazy
Jan 26, 2006 05:26 PM
tegra33
Sep 23, 2004 08:07 PM
LS Teg
Mar 21, 2002 02:47 PM
