93 b18a1 into 94 civic vtec
So i wrecked my teg and want to put the b18 into an eg. I should already have everything for the swap minus the cable conversion kit, correct? thanks ahead just checking before i start wrenching
Re: 93 b18a1 into 94 civic vtec
You are going to have to change a lot of things actually. You can't use the DA shift linkage, you need a 94 up integra linkage, the DA mounts won't work, you need to either switch the drivers side mount bracket to an EG B series 2 bolt style and switch to a hydro tranny (easiest) or get a mount kit like this one http://www.hamotorsports.com/40150mounts.html . You'd be better off just selling the whole swap to someone with an EF or something and buyin a 94+ engine swap
D16Z6TURBO
04-27-2006 10:31 AM
seeeya04
Welding / Fabrication
06-07-2005 04:15 PM
