LSVTEC questions!!!!!!!!!
Old Mar 7, 2010 | 06:12 PM
nano1589's Avatar
Default LSVTEC questions!!!!!!!!!
Im using a b16a2 head, can I use the LS distributor? The motor is going in a 93 civic dx (non vtec) I have to run a P2T (b16a2) ECU or get the stock ecu chipped? And finally I have to run the vtec wires to the ECU? Am I rigth or im confussed!!? correct me please if im wrong, if not let me know so i can finish with the swap! thanks a lot!!!
Old Mar 27, 2010 | 04:20 PM
SPEEDY-G-TypeR's Avatar
Default Re: LSVTEC questions!!!!!!!!!
im doing the same thing and i used a Ls dist. u just got to cut one of the sides off of it and it will work it worked for me ....
Old Mar 30, 2010 | 04:49 PM
DVDr's Avatar
your best bet is chip the stock ecu so you stay OBD1 , yes you have to run a few wires for VTEC, knock sensor and vtec pressure switch ( so 3 wires total )
diagram
LsVtecFoti
Dec 6, 2007 11:22 AM
.M.
Jul 13, 2005 10:54 PM
@irborne
Apr 4, 2003 01:14 PM
ThePro
Feb 5, 2003 05:42 PM
CopperSol
Apr 1, 2002 04:19 PM
