F22/h22/H23 Build Questions
ok so i have 3 of these motors laying around and im wanting to piece together a solid motor for boost so i want to use the f22 block.
engines i have
F22B DOHC JDM
H22A4
H23A1
ok so this is what i want to use and im not sure if its possible.
F22 block
H22 head
H23 transmission
would all these bolt up together and if so what head gasket would i use?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Edit/Delete Message
engines i have
F22B DOHC JDM
H22A4
H23A1
F22 block
H22 head
H23 transmission
Edit/Delete Message
Re: F22/h22/H23 Build Questions
engines i have
F22B DOHC JDM
H22A4
H23A1
F22 block
H22 head
H23 transmission
Edit/Delete Message
engines i have
F22B DOHC JDM
H22A4
H23A1
F22 block
H22 head
H23 transmission
Edit/Delete Message
buy a f23 non vtec block and slap on the h22 head do research on the f23 vtec!!!!! its a custom build like doing a b20vtec your power will be like k20 power or more depends on how you set up the build and for cheaper also
brad_prelude
12-22-2004 01:09 AM
