Help! Almost done my B16A swap in 99 civic
I'm reusing my stock harness (obd2b) and I'm running a P2T Si computer, the problem I'm having is reusing my Y8's injectors on my B16. It seems as though they're not going into the manifold, since they're too wide at the tip by the nozzle and they seem like they're too long as well. I'm not sure if I'm suppose to be using these injectors but it seems every swap guide says I can use any honda injector as long as the harness clips match and you use the correct injectors to whatever OBD computer you run.
Here are some pics, did anyone experience this before?
Re: Help! Almost done my B16A swap in 99 civic
I never got B16 injectors with it, I put the motor together from a bunch of different parts.
Turns out it was the Manifold, I got a new one and the problem is fixed.
Fresh'86
03-03-2010 10:02 PM
W0oT
06-13-2002 05:41 PM
Spaceballsthelunchbox
10-19-2001 08:39 PM
