h22 in 97 civic cx
h22 in 97 civic cx
i have a 97 civic cx and im putting in a h22a1 . i search the FAQ and there 125 pages . what i would like to know is what all i need to mod on my wiring harness as mines a 1 pice?
links with pics that work would be alsome thanks
Re: h22 in 97 civic cx
There's some posts at the beginning of the "hybrid section" with thousands of hits about this swap. Take a look at those. I bought a OBD2A to OBD1 conversion harness when I did mine. Ebay has these cheap just make sure you get the right one. I used the h22a ECU OBD1 and your car's wire harness is OBD2A. You still have to add a couple of wires for VTEC to work and there were a couple of plugs under the hood you either need to cut the mating half off from the old D16 engine or cut the plugs off your car's harness and wire direct.
You havent done enough searching at all.. your just lazy.. if you check this hybrid thread you would know that on one of the sticky theres an h22 thread for swapping into civics..
I did search all the **** is old and none of the pics were working but yeah thanks for adding nothing to help
Int3graz
23
09-26-2011 02:50 PM
Mad-Mike
11
06-23-2011 03:40 AM
Civic97s
07-30-2006 06:27 AM
