H22 1 plug Dizzy Question.. Pic inside (please help)
Old Apr 23, 2010 | 01:30 PM
Chesh's Avatar
Default H22 1 plug Dizzy Question.. Pic inside (please help)
ive got a H22a in an EK. the dizzy is a standard prelude dizzy (TD-60U), but the standard td-60u dizzy's are a two plug.. where as mine is a one plug
here's a picture of the plug
TD-60U dizzy's usually have two plugs, one like this (but only 7 pins not 8) and they have another little seperate plug
ive searched around and asked alot of people and they dont know whats going on.. the only thing i can think is the two plug has been modded to a one plug. but i dont see why and how
the problem is i need to change the dizzy but i dont know what to buy. ive bought another td-60U.. will i need to modify that ?
hopefully someone knows what i am talking about
Old Apr 23, 2010 | 04:04 PM
perseverance's Avatar
Default Re: H22 1 plug Dizzy Question.. Pic inside (please help)
the two plugs are for an obd-1 dizzy, 1 plug is obd2. what year ek and what trim will decide what dizzy to use. i personally just add the plugs to the existing engine wiring harness, stripping and soldering each wire, and keep both the obd1 and obd2 dizzy plugs for easy of swapping out. i believe they also sell distributor adaptors. check out xenocron, moates, and possibly rywire..they should have what you need. makes it easy if you're not into rewiring.
Old Apr 23, 2010 | 04:12 PM
SL0WEGG's Avatar
doesn't matter what year ek, they are all obd2
Old Apr 25, 2010 | 05:12 AM
Chesh's Avatar
thanks for that perseverance.. i think this is what i need
http://rywire.com/store/obd2b-dserie...e5f84b440af098
Old Apr 26, 2010 | 12:08 PM
cmwright1986's Avatar
^^ actually it does matter... the 99-00 civic's are obd2b, and the 96-98 civic's are obd2a. the obd2a and obd2b distributor plugs are different from one-another. just an fyi
Old Apr 26, 2010 | 02:30 PM
ditto that, thanks.
cloviskilla
Jan 14, 2011 07:40 PM
thapimpfromchi
11
Mar 8, 2006 04:36 AM
pootie.teng
Feb 25, 2004 12:48 PM
turbo sol
Apr 28, 2003 11:08 AM
im_poor
Apr 17, 2003 11:27 AM
