what color is tach signal on a 99 y8 dis
hey i using a 99 dist from a y8 in my 95 civic i need to know what color from the distrib is the tach signal i got a tan a tan/blu light blue yellow/green for the top four
and bottom four is black white/blue white black/yello
i got car running but have no tack.
the engine harness is a 99 integra ls harness the car is a 94dx
Re: what color is tach signal on a 99 y8 dis
You will have to add an additional wire coming from the distributor. When you open it up you will see a post ( on the coil or ICM) that has no connector on it. Just add a wire from there to the wire on the engine harness. A crimp-on spade connector works fine for this.
