h22 in my eg wont work anymore.
ok.well here goes the story.
i purchased a wrecked eg hatch with h22 runing an driving.
i took the swap and slaped it in my car.everything from the other car and used it on mine.
ok...well when i cranked it up today it ran fine,when i looked in the engine compartment i noticed a little fuel leaking from the fuel filter.its from the line that goes on it.guess i didnt put it on right the first time.
SO.... i turned the car off.loosened it and adjuseted it.and tightend it back up.ok..well fuel leaked out so i got the hose and kinda washeed it off.it wasnt on hi,cause i was just filling my raidator right before i started it.
well i went back in the car to start it to recheck for leaks.
it turned on for maybe 10 seconds then cut off.then i tried to start again.it just turned.with wich sounded like a spark from the back,(were i have my battery),then i tried again,same thing.then again,same thing but i heard one from the front.then after that my dash lights went dim.and nothing now.
it wont crank,no lights,no horn,nothing....like i have no battery on it.
i checked all fueses under dash,under hood.thhe only one looked bad was a 50amp but its the "option" slot?
well i changed battery and same thing no power.i took the 50amp fuse out and replaced it off another civic and same.
also took the 80amp battery fuse out the other car and same.
no power to anything....
any suggestions.
any help very appreciated.
any suggestions.
redline7
07-16-2007 08:49 AM
