Help: H22 swap in EK vibration at acceleration
I have had this swap for a year now and i finally got an LSD tranny for it (M2B4) but since i took off the tranny i decided to go get the clutch resurfaced etc... So when i was putting the driver side axle and one of the bearings fell so i bought new axles off kragen 89 integra for pass. side and a 90 integra for driver side. Car doesnt vibrate much when its idling its when i start driving it pass 15mph...........i've put it on the lifters and put it on gear and doesnt make any noise...... Thanks for help in advance
Re: Help: H22 swap in EK vibration at acceleration
nah its not a lil vibration like as soon as i start gaining speed the whole car vibrates
and yes i made sure everything was tight cus i have at least taken off the axles like 5 times to check that the axles are still fine and then bolt everything back up
i checked tha halfshaft and it has no play, cus i put the car up in the air and it doesnt vibrate at all
i lifted the suspension all the way and the car is running fine now so figure its my ride height lol........ since i was rokin 195/55-15 and bought some other rims that had 195/50-15, my best bet is that ihave to rock 16's
I Have the same problem hopefully i can solve this the same way due to ride height.👍
It's bad axle alignment. It comes from bad CV joint or if you are lowered, obviously this will cause axle alignment to be off.
Rise VTEC
Transmission & Drivetrain
12-22-2014 09:38 PM
SPEEDQUEST INC.
12-06-2004 08:24 PM
