dont feel vtec kicking in
Old 04-21-2010, 09:57 AM
99lsvtecdc's Avatar
Default dont feel vtec kicking in
I got a 99 ls with a b16 head and a gsr ecu. My engine rev up to past 8k no check engine lighton. Stock intake and exhaust. But don't hear the vtec pop or the pull. Have idea what could it be?????
Old 04-21-2010, 01:03 PM
rustanghunter's Avatar
Default Re: dont feel vtec kicking in
if no cel is coming on i would say if you want more pull open up your intake and exhaust, vtec doesnt pop......
Old 04-22-2010, 06:16 PM
hondamas's Avatar
check your ait sensor, u will never see vtec if it aint plugged in, it belongs on ur intake and if u went aftermarket n dnt have it plugged in then that could be the problem, check wiring if u switched computers. i thought it was the wiring on mine and ended up being that stupid sensor. tuners can bypass that upon tuning. good luck.
Old 04-23-2010, 05:40 AM
perseverance's Avatar
is ur check engine light coming on and turning off when u first turn the key on? if not, it's possible you have a CEL and someone disconnected the bulb. second option would be that you're not running a vtec ecu, therefore it wouldn't throw a cel for vtec not working.
Old 04-23-2010, 07:48 AM
King of the One Liners
2fastGSR's Avatar
Could be the welds on the intake manifold
Old 04-23-2010, 09:03 AM
ketchup's Avatar
not enough torque.
Old 04-25-2010, 07:17 PM
BigBlock22's Avatar
you're actually not suppose to feel it switch over, theres suppose to be a smooth transition into vtec.... it does not "pop!"
its probably working just fine
Skunk2jdmgsr
07-27-2014 05:03 PM
Buckshot
01-24-2009 10:03 PM
h2b-ubeezy
12
06-05-2008 08:11 AM
Littlegreend15
10
04-23-2005 11:48 AM
elflacoloco
09-02-2004 12:03 PM
Quick Reply: dont feel vtec kicking in
